Alright, gonna give tons of informations, 'cause need to root my DOOGEE X10 [I can't even change my font, also phone came with preinstall malware programs (adups.fota*)]
USE CTRL+F to find required info
------ DiskInfo ------
------ AIDA64 ------
[[SUPER TIRED OF WRITING] Hopefully that's enough.
--- INTERNAL STORAGE ---
--hmzram0 [Swap] - 332MB
Not mounted
--- INTERNAL STORAGE (MLC-NAND) ---
--preloader mtdblock0 - 18 MB
Not mounted
--pro_info mtdblock1 - 12 MB
Not mounted
--nvram mtdblock2 - 48 MB
Not mounted
--protect_f mtdblock3 (/protect_f,... - 18 MB
16,1 MB used - 1,9 MB free
--seccnfg mtdblock4 - 12 MB
Not mounted
--uboot mtdblock5 - 12 MB
Not mounted
--boot mtdblock6 - 18 MB
Not mounted
--recovery mtdblock7 - 18 MB
Not mounted
--secstatic mtdblock8 - 12 MB
Not mounted
--misc mtdblock9 - 18 MB
Not mounted
--logo mtdblock10 - 12 MB
Not mounted
--md1img mtdblock11 - 54 MB
Not mounted
--nvcfg mtdblock12 (/nvcfg) [rawfs] - 18 MB
--expdb mtdblock13 - 18 MB
Not mounted
--system mtdblock14 - 1,2 GB
Not mounted
--userdata mtdblock15 - 5,1 GB
--- UBIFS ---
--/data [ubifs] - 4,4 GB
1010 MB used - 3,4 GB free
--/system [ubifs] - 1 GB
997 MB used - 68,2 MB free
--/cache [ubifs] - 225 MB
276 KB used - 225 MB free
--- TMPFS MOUNT POINTS ---
--/dev [tmpfs] - 221 MB
88 KB used - 221 MB free
--/mnt [tmpfs] - 221 MB
0 B used - 221 MB free
--/storage [tmpfs] - 221 MB
0B used - 221 MB free
--/storage/self [tmpfs] - 221 MB
0B used - 221 MB
--- MEMORY ---
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
--- UBIFS ---
0B used - 221 MB
--- MEMORY ---
--RAM - 443 MB
310 MB used - 132 MB free
--Swap - 332 MB
275 MB used - 56,4 MB free
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
--- UBIFS ---
0B used - 221 MB
--- MEMORY ---
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
Not mounted
--- UBIFS ---
0B used - 221 MB
--- MEMORY ---
--RAM - 443 MB
--Swap - 332 MB
--- System ---
Manufacturer - DOOGEE
Model - DOOGEE X10
Brand - DOOGEE
Device - doogee-X10
Hardware - mt6570
Platform - mt6570
Product - doogee-X10
Serial - [NOT SHOWING]
Installed RAM - 512MB
Total Memory - 443 MB
Available Memory - 148 MB
Internal Storage Total Space - 4481 MB
Internal Storage Free Space - 3467 MB
Bluetooth Version - 4+
--Device Features:
android.hardware.audio.output
android.hardware.bluetooth
android.hardware.bluetooth_le
android.hardware.camera
android.hardware.camera.any
android.hardware.camera.autofocus
android.hardware.camera.flash
android.hardware.camera.front
android.hardware.faketouch
android.hardware.location
android.hardware.location.gps
android.hardware.location.network
android.hardware.microphone
android.hardware.screen.landscape
android.hardware.screen.portrait
android.hardware.sensor.accelerometer
android.hardware.sensor.light
android.hardware.sensor.proximity
android.hardware.telephony
android.hardware.telephony.gsm
android.hardware.touchscreen
android.hardware.touchscreen.multitouch
android.hardware.touchscreen.multitouch.distinct
android.hardware.usb.accessory
android.hardware.wifi
android.hardware.wifi.direct
android.software.app_widgets
android.software.backup
android.software.connectionservice
android.software.device_admin
android.software.home_screen
android.software.input_methods
android.software.live_wallpaper
android.software.midi
android.software.print
android.software.webview
com.google.android.feature.FASTPASS_BUILD
--- CPU ---
SoC Model - MediaTek MT6570
Core Architecture - 2x ARM Cortex-A7 @ 1300 MHz
Manufacturing Process - 28 nm
Instruction Set - 32-bit ARMv7
CPU Revision - r0p3
CPU Cores - 2
CPU Clock Range - 604 - 1300 MHz
Core 1 Clock - 1300 MHz
Core 2 Clock - 1300 MHz
CPU Utilization - 100 %
Scaling Governor - interactive
Supported ABIs - armeabi-v7a, armeabi
Supported 32-bit ABIs - armeabi-v7a, armeabi
AES - Not Supported
NEON - Supported
SHA1 - Not Supported
SHA2 - Not Supported
--- Display ---
Screen Resolution - 480 x 854
Panel ID - rm68172_boe50_xingliang_fwvga
xdpi / ydpi - 240 / 240 dpi
GPU Vendor - ARM
GPU Rendered - MALI-400 MP
GPU Cores - 1
Refresh Rate - 57 Hz
Default Orientation - Portrait
OpenGL ES Version - 2.0
--OPENGL ES Extensions
GL_EXT_debug_marker
GL_OES_texture_npot
GL_OES_vertex_array_object
GL_OES_compressed_ETC1_RGB8_texture
GL_EXT_compressed_ETC1_RGB8_sub_texture
GL_OES_standard_derivatives
GL_OES_EGL_images
GL_OES_depth24
GL_ARM_rgba8
GL_ARM_mali_shader_binary
GL_OES_depth_texture
GL_OES_packed_depth_stencil
GL_EXT_texture_format_BGRA8888
GL_OES_vertex_half_float
GL_EXT_blend_minmax
GL_OES_EGL_image_external
GL_OES_EGL_sync
GL_OES_rgb8_rgba8
GL_EXT_multisampled_render_to_texture
GL_EXT_discard_framebuffer
GL_OES_get_program_binary
GL_ARM_mali_program_binary
GL_EXT_shader_texture_lod
GL_EXT_robustness
GL_OES_depth_texture_cube_map
GL_KHR_debug
GL_ARM_shader_framebuffer_fetch
GL_ARM_shader_framebuffer_fetch_depth_stencil
--- Android ---
Android Version - 6.0 (Marshmallow)
API Level - 23
Android Security Patch Level - 2017-07-05
Rooted Device - No
Android ID - [NOT SHOWING]
Baseband - MOLY.WR8.W1449.MD.WG.MP.V111.4.P1, 2017/06/16 10:48
Build ID - DOOGEE-X10-Android6.0-20170921
Codename - REL
Fingerprint - DOOGEE/doogee-X10/doogee-X10:6.0/MRA58K/20170608.142922:user/release-key
ID - MRA58K
Incremental - 1505963999
Java Runtime Version - Android Runtime 0.9
Java VM Version - ART 2.1.0
Java VM Heap Size - 128 MB
Kernel Architecture - armv7l
Kernel Version - 3.18.35 (user@linux-user) (gcc bersion 4.8 (GCC) ) #2 SMP PREEMPT Thu Sep 21 12:50:51 CST 2017
Tags - release-keys
Type - user
Google Play Services Version - 17.1.22 (040304-245988633)
OpenSSL Version - BoringSSL
ZLib Version - 1.2.8
ICU CLDR Version - 27.0.1
ICU Library Version - 55.1
ICU Unicode Version - 7.0
Android Language - [STILL DON'T CARE]
Configured Time Zone - [STILL DON'T CARE]
UpTime - [STILL DON'T CARE]
--- Devices ---
--USB Device - Linux 3.18.35 musb-hcd MUSB HDRC host driver--
Manufacturer - Linux 3.18.35 musb-hdc
--RAM - 443 MB
--Swap - 332 MB
--- System ---
Model - DOOGEE X10
Brand - DOOGEE
Device - doogee-X10
Hardware - mt6570
Platform - mt6570
--Device Features:
--- CPU ---
CPU Revision - r0p3
CPU Cores - 2
AES - Not Supported
NEON - Supported
--- Display ---
GPU Vendor - ARM
GPU Cores - 1
GL_EXT_debug_marker
GL_OES_texture_npot
GL_OES_EGL_images
GL_OES_depth24
GL_ARM_rgba8
GL_EXT_blend_minmax
GL_OES_EGL_sync
GL_OES_rgb8_rgba8
GL_EXT_robustness
GL_KHR_debug
--- Android ---
API Level - 23
Rooted Device - No
Codename - REL
ID - MRA58K
Tags - release-keys
Type - user
--- Devices ---
Model - DOOGEE X10
Brand - DOOGEE
Device - doogee-X10
Hardware - mt6570
Platform - mt6570
--Device Features:
--- CPU ---
CPU Revision - r0p3
CPU Cores - 2
AES - Not Supported
NEON - Supported
--- Display ---
GPU Vendor - ARM
GPU Cores - 1
GL_EXT_debug_marker
GL_OES_texture_npot
GL_OES_EGL_images
GL_OES_depth24
GL_ARM_rgba8
GL_EXT_blend_minmax
GL_OES_EGL_sync
GL_OES_rgb8_rgba8
GL_EXT_robustness
GL_KHR_debug
--- Android ---
API Level - 23
Rooted Device - No
Codename - REL
ID - MRA58K
Tags - release-keys
Type - user
--- Devices ---
--RAM - 443 MB
--Swap - 332 MB
--- System ---
Model - DOOGEE X10
Brand - DOOGEE
Device - doogee-X10
Hardware - mt6570
Platform - mt6570
--Device Features:
--- CPU ---
CPU Revision - r0p3
CPU Cores - 2
AES - Not Supported
NEON - Supported
--- Display ---
GPU Vendor - ARM
GPU Cores - 1
GL_EXT_debug_marker
GL_OES_texture_npot
GL_OES_EGL_images
GL_OES_depth24
GL_ARM_rgba8
GL_EXT_blend_minmax
GL_OES_EGL_sync
GL_OES_rgb8_rgba8
GL_EXT_robustness
GL_KHR_debug
--- Android ---
API Level - 23
Rooted Device - No
Codename - REL
ID - MRA58K
Tags - release-keys
Type - user
--- Devices ---
