Help Double data in contacts
Niski
Hi. Something strange happens with my contacts. There is no problems during adding a new number. Everything is properly saved but after a few seconds, when I open created contact once again, included data become doubled. This generally regards addresses. It's weird because gmail stores those contacts without any problems, only my S3 displays them with double information. How can I fix it?
What is more, when I add a new contact through the gmail then everything works fine. The problem occurs when this contact is being saved directly by the phone.
Check your settings in 'Contacts to display' in your Contacts app. With the app open, press Menu then 'Contacts to display'. De-select sources you don't need.
