Well this sucks!
If the fingerprint security option is enabled, there is no swipe required.
All I do is place the appropriate finger on the button and press in one motion. It instantly opens up to the home screen.
However, I purposely tried using a finger that has not been entered, and at that point I had to swipe before reentering the correct finger and/or pin. It could very well be that your print is not being read properly the first time.
Obviously this does not help users that would prefer to use gestures and/or pin.
I do like the home button screen-on feature,it's (almost) a suitable replacement for LG's Double-Tap-To-Wake..........For the first day of use, I had no security enabled and all it took was a swipe or a home button press to start.
Incidentally, just a personal opinion, the fingerprint feature is so much better that it is the equivalent off pressing the home button to unlock the phone. I don't even notice that it is there.
My bad. I stand corrected. Seven lashes and a shot of single malt.
Hiya @usualantics !Ok hopefully someone will know why this is happening but for some reason my s7 has a swipe unlock screen before the pattern unlock screen. Is there a way of turning the first screen off so when I wake it up it goes straight to the pattern like the previous models? It's really annoying to the point I might send it back and stick with my s5
