Help Double lock screen
The new update did something similar to my phone. Now I have to Swype before I can attempt to unlock despite the fact that I have the fingerprint option set up. Also, for some reason one of the symbols on the first lock screen (so stupid) is on what appears to be Korean??? Wtf?! How do I fix this. I don't want this stupid extra lock screen. I'm attaching picture of the first lock screen. The symbol I don't recognize is right after the "5"
It's Chinese I think. 月 means "month", 달 is Korean for "month". Have you installed or updated any "free" adware apps recently, like anything by GO, such as GO SMS, GO Keyboard, etc.? Because those can put useless extra lock-screens in.
no. I haven't down loaded any of those apps. This all started after I updated my software.
CyanogenMod 13.1 has a 'Straight To Pin' setting which bypasses the swipe to unlock when you have PIN or pattern security selected.
It also enables you to select a white on black theme, and easy rooting so I can install Recently to tame the ridiculous new carousel Recent Apps view.
It's only this combination of features that's enabled me to finally upgrade from Android 4.
Hello i have a Nokia 3.1 Plus and I am having this same issue I have to swipe before I even get to the keypad for my code is there any way to fix this issue? Any help would be greatly appreciated
