Help Double Tap Home Screen setting
conncr
With KitKat and Lollipop on the Droid Turbo, I was able to set my phone to open a particular application when I clicked the home button twice. The settings were in the accessibility section if I recall correctly.
Now that I have updated to Marshmallow, I am not finding a location to change the settings to open a different app. Does anyone know where I can make that change in the Marshmallow settings?
Thanks.
conncr
What launcher are you using?
I use Nova Launcher Prime and just checked it on the Turbo for you. In the Gestures section you can tell it to launch a specific app when the Home key is tapped.
... Thom
I cannot find a way to do it in the pre-installed launcher.
I cannot find a way to do it in Tasker or MacroDroid but both of them provide some other options like Shake.
... Thom
