jason.sgtski
Member
I'm a former iphone and ipod touch user.
I use itunes for my podcasts and playlists.
I have double twist up and running and using my playlist from itunes.
So, the issue im having may just be the learning curve, or maybe it may not be the best for what i want to do.
Any of you DT users use it to handle your podcasts or is there something better?
Does it take along time to sync for you too?
Could it be the SD card that came with the phone, should i get a higher class SD card?
DT shows my available memory as 6GB free, so its not moving a whole lot, I'm afraid to go to a 16GB card and keep syncing my podcasts to it.
my PC is win XP Pro.
I dont like the way DT handles my podcasts from itunes, thats why i want to try using DT.
