Apps Doubt about Activities life cycle
jonathanrz
Member
Hi
I have an application that have two activities, lets name they A and B for convention.
A calls B.
In activity B, I implemented the method onSaveInstanceState to save data members on the Bundle, and in the method OnCreate I implemented to take the datas from the Bundle.
Everything is working fine, but if I kill the application or restart the fone, the application starts with activity A, how can I inform to Android that he have to call activity B or what I have to implement?
I believe that restart the fone is a way to simulate the Android procedures when he will kill my application because low memory. Am I right?
Sorry for the bad english.
I'm having another problem too, in the same application, I have three activities, lets name they A, B and C for convention.
A calls B with StartActivity.
When user hit the back/cancel button, I have to call Activity C, so I implemented in OnPause function to call Activity C, but I need return from activity C, so I called Activity C with startActivityForResult and implemented the method onActivityResult in Activity B to get the return.
Everything is working fine, but when activity C finishes, the application is getting back to Activity A, and I need Activity B.
I have to call Activity B explicitly again or I made something wrong?
I believe if your activity is truly "killed" either by the phone rebooting, or the OS removing it from memory, you will lose the savedInstanceState Bundle
If you need data to persist beyond that, you shoud look at SharedPreferences or other more persistent storage.
Data Storage | Android Developers
As to your second post, in order to stop the back button from going back to "A" you will need to Override the onKeyPress event and capture it so that the OS cannot process it
see here:
is there a default back key(on device) listener in android? - Stack Overflow
hope that helps!
