Hello once again, i still havent figured out how to fix my signal, so i called At&t and they couldnt fix it, (not a big surprise) So im just going to try something and see if it works.
Ok so i have a Samsung Captivate Galaxy S. Android Phone - Captivate Smartphone | Samsung Captivate Galaxy S Android Smartphones
And i recently installed gingerbread 2.3.6
And i am wanting to just completely revert to 2.2 or 2.1 SOMETHING like it originally was cause ginger is causing not but problems.
So if anyone has a thingy for it i would be most grateful.
I used Odin to install the update and now i just need the original stuff to revert it back to its old self.
I just need the
PIT, PDA, PHONE,and CSC
**FOR EXAMPLE**
Gingerbread's is:
PIT: s1_odin_20100512.pit
PDA: CODE_I9000XXJVU_CL851880_REV03_user_low_ship.tar.md5
PHONE: MODEM_I9000XXJVU_REV_00_CL1092175.tar.md5
CSC: GT-I9000-CSC-MULTI-OXAJVU.tar.md5
So i just need the codes for the original frame-ware thing.
Then i should be good to go.
If it helps ANY im using GINGERBREAD XXJVS.
All i wanted to do was update my phone to keep it up to date and never wanted all this trouble to happen.
I tried using Kies for a simple update but of course Kies took FOREVER to connect to my phone and always timed out. So i gave up on it.
Is there a better thing to use to update my phone when it needs it?
I am NEVER going back to Ginger or any other ever again after i get this fixed.
Oh and Frisco if my thread is in the wrong place and needs to be moved then feel free to move it, i apologize if its in the wrong place again.
I just need the
**FOR EXAMPLE**
Gingerbread's is:
