It is a keyboard issue, for sure. Google kb works perfectly. Updated password with the network & somehow solved the issue. So, we're down to app incompatibilities. I'm presuming those will be addressed with time??
Flashing the factory images is fairly straightforward
While they can seem very easy and helpful, I'd urge you to avoid using any toolkits. Using those, you won't learn anything about what is actually being done, and if something goes wrong, you won't have a clue about what has been done so far and what failed and it will be hard for anyone to help out after that.
Basically, the sequence of steps is this.
Rather than type out all the steps in detail here, I'll point you to the most comprehensive guide that I have found so far - http://forum.xda-developers.com/google-nexus-5/general/tutorial-how-to-flash-factory-image-t2513701
- Download & install ADB/Fastboot drivers to your PC - test it
- Download the correct factory image from developers.google.com/android/nexus/images
- Unlock bootloader if it isn't already unlocked - this WILL delete all your data, so backup your phone data before this
- Execute the flash-all.bat script from the factory image you downloaded, immediately followed by going to recovery and performing factory data reset (if you are flashing Android 5.x, the flash-all.bat doesn't seem to work right - so, you'd flash the individual images in the right sequence)
Read the first post at least twice so you understand the sequence perfectly.
Out of curiosity, what is it about 5.0 that you can't stand? I've been using 5.0 since it was released and can't find any reason to go back to kitkat (well, except XPosed Framework - but I think 5.0 has a lot of benefits that make me want to stick to it even without XPosed)
Nice thing about a N5 is that they're damn near impossible to brick.Really this lollipop upgrade sucks. Facing Hell lot of problems.My battery goes drain every time.And I'm wondering that to where should I go to check my clicked pics !.I could not see any gallery .
For every user who posts here with problems there's probably thousands who install 5.0 OTA and have none. I'm one of them. Did the standard OTA update, didn't do a reset or anything else. No problems. In fact, since starting with Android 1.0 on the original G1 I've done many OTA updates and never done a reset afterward and have never had problems. Other people I know have had multiple trouble-free OTA updates.I have had the offer of Lollipop for a couple of weeks now, but am hanging back because of all the problems people seem to be experiencing.
Before I download it, I'd really like to know whether all the people who have encountered problems have overcome them (or not) by doing the factory reset that is being recommended on here.
Come on, people, please let me (and I'm sure other interested parties) know.
Matched performance without the Google hipster tagging alongside.
You most certainly can disable Google Now and a lot of other things, as before, in the Google Settings app (definitely around since KitKat).For every user who posts here with problems there's probably thousands who install 5.0 OTA and have none. I'm one of them. Did the standard OTA update, didn't do a reset or anything else. No problems. In fact, since starting with Android 1.0 on the original G1 I've done many OTA updates and never done a reset afterward and have never had problems. Other people I know have had multiple trouble-free OTA updates.
So...will you have any trouble? Need to do a reset? It's possible.
Are the odds good that you can do a simple OTA update and go? Yes!
Just do it...
And I'm more surprised that it's SwiftKey, of all apps!! I'm literally at my wits end . . .I'm sure they will. Frankly it's surprising some apps are taking so long. The developer preview was out in July and it hasn't changed that much. I'd contact the dev's of the individual apps and see what they say.
I must admit - I'm unclear about the issue nowI've really tried to make myself like this upgrade, but the more I use it, the more I don't like it. I'm what you'd call a "noobie" in terms of tinkering with devices. Gonna give this downgrade a shot, as 5.0 just isn't for me at all and the factory reset rendered nothing different. @jj14x, is the method you listed fairly easy & straight forward?
From your earlier posts, it seemed like there was just some issue with an incompatible app, and that other issues were fixed. Is there some other issue going on? Or is that app critical enough to warrant going back to kitkat?
