Download path
SNbc
Hi,
I tried to tap the “SD-CARD” in the “ Folder for files” wanting to save the downloads directly to the SD Card but it does work.
How to set the path to SD Card?
I've never used the app, but from the description it seems like all it does is move your folders from the internal memory to the sd card. So it looks like you would have to select a file and then in the menu press on move to sd card. What happened when you did the above?
IMHO this app is a waste of time cuz your file manager does the exact same thing.
