Downloading Navfree maps on PC and transfuring to phone (pc client)
funkytwig
The maps for navfree are over 400MB so I dont want to download them over 3G (I would imagine others don't as they will blow or almost brow a whole months download allowance for many). Is there a way of downloading them to PC then transferring them to phone and getting navfree to use them?
Also was wondering is there a PC client for Android (i.e. simpler to iTunes) for installing applications?
You'd have to check with the app developer. It really depends on how the data is stored. It may be possible. It may not be possible. Do you not have WiFi for the download?
