Dr Android: Easily Get Your Android Phone Info
Yumi
As its name suggests, Dr Android is a doctor for android phone. It helps you learn phone info, battery info, battery history and usage statistics.
Main features:
1) IMEI, network connections, signal strength and more info you want to know.
2) Include battery health, current temperature, voltage, usage time etc.
3) Apps? battery usage is listed by different ways (CPU, Network, GPS, Sensor, Partial usage).
4) Apps usage statistics (like start times, running time, etc.). It tells you the useful and useless apps)
It is available on market(search Dr Android developed by Gmobilesoft )
