Drastic DS emulator help?
So I downloaded DraStic 2.6.2 from 4shared, along with pokemon black 2 and white 2 from coolrom. I started the Drastic app, and it seemed to work fine, until after about 1 minute , it went black and returned me to the menu screen. I tried again and again, but it kept happening, even after I tried different downloads from other sources. Afterwards, I tried the demo version from the play store, and all it would do after I selected the rom I wanted to play, is load forever. I left it for 10+ minutes and it was still loading. I know the roms work, because I tried them out on nds4droid, and they were working fine, besides the very slow fps from the app. So I was wondering if anyone else has had these problems before, and how they solved them. By the way, this is all on my sprint GS3, in case that helps.
We can't really provide help or discuss anything you might have downloaded from 4shared, because that's copyright infringement and thus against forum rules. Although I've not tried Drastic, but the Play store reviews for this emulator don't look very promising, nearly all one star....with "junk", "crap", "garbage", "doesn't work" etc.
You might want to try and use an emulator that works instead....like NDS4Droid. :)
