Gravity Games
I've been having trouble trying to draw more than one square in OpenGLES 2.0, and have been experimenting for a good hour and a half now. Can anyone else figure out what's going wrong?
Adding vertex data:
Draw method:
Adding vertex data:
Code:
for(int i=0; i<height; i++){
for(int j=0; j<width; j++){
drawOrder.add((short)(squareCoords.size()+0));
drawOrder.add((short)(squareCoords.size()+1));
drawOrder.add((short)(squareCoords.size()+2));
drawOrder.add((short)(squareCoords.size()+3));
squareCoords.add((float)j*TILE_SIZE);
squareCoords.add((float)i*TILE_SIZE);
squareCoords.add(0f);
squareCoords.add((float)(i+1)*TILE_SIZE);
cubeTextureCoordinateData.add(0f);
cubeTextureCoordinateData.add(1f);
// initialize vertex byte buffer for shape coordinates
ByteBuffer bb = ByteBuffer.allocateDirect(
// (# of coordinate values * 4 bytes per float)
squareCoords.size() * 4);
bb.order(ByteOrder.nativeOrder());
vertexBuffer = bb.asFloatBuffer();
for(int i=0; i<squareCoords.size(); i++){
vertexBuffer.put(squareCoords.get(i));
vertexBuffer.position(0);
// initialize byte buffer for the draw list
ByteBuffer dlb = ByteBuffer.allocateDirect(
// (# of coordinate values * 2 bytes per short)
drawOrder.size() * 2);
dlb.order(ByteOrder.nativeOrder());
drawListBuffer = dlb.asShortBuffer();
for(int i=0; i<drawOrder.size(); i++){
drawListBuffer.put(drawOrder.get(i));
drawListBuffer.position(0);
ByteBuffer tb = ByteBuffer.allocateDirect(cubeTextureCoordinateData.size() * 4);
tb.order(ByteOrder.nativeOrder());
mCubeTextureCoordinates = tb.asFloatBuffer();
for(int i=0; i<cubeTextureCoordinateData.size(); i++){
mCubeTextureCoordinates.put(cubeTextureCoordinateData.get(i));
mCubeTextureCoordinates.position(0);
Draw method:
Code:
// Add program to OpenGL ES environment
GLES20.glUseProgram(mProgram);
GLES20.glBlendFunc(GLES20.GL_SRC_ALPHA, GLES20.GL_ONE_MINUS_SRC_ALPHA);
GLES20.glEnable(GLES20.GL_BLEND);
// get handle to vertex shader's vPosition member
int mPositionHandle = GLES20.glGetAttribLocation(mProgram, "vPosition");
// Enable a handle to the triangle vertices
GLES20.glEnableVertexAttribArray(mPositionHandle);
// Prepare the triangle coordinate data
GLES20.glVertexAttribPointer(mPositionHandle, COORDS_PER_VERTEX,
GLES20.GL_FLOAT, false,
vertexStride, vertexBuffer);
// get handle to fragment shader's vColor member
int mColorHandle = GLES20.glGetUniformLocation(mProgram, "vColor");
// Set color for drawing the triangle
GLES20.glUniform4fv(mColorHandle, 1, color, 0);
//Set Texture Handles and bind Texture
mTextureUniformHandle = GLES20.glGetAttribLocation(mProgram, "u_Texture");
mTextureCoordinateHandle = GLES20.glGetAttribLocation(mProgram, "a_TexCoordinate");
//Set the active texture unit to texture unit 0.
GLES20.glActiveTexture(GLES20.GL_TEXTURE0);
//Bind the texture to this unit.
GLES20.glBindTexture(GLES20.GL_TEXTURE_2D, mTextureDataHandle);
//Tell the texture uniform sampler to use this texture in the shader by binding to texture unit 0.
GLES20.glUniform1i(mTextureUniformHandle, 0);
//Pass in the texture coordinate information
GLES20.glVertexAttribPointer(mTextureCoordinateHandle, mTextureCoordinateDataSize, GLES20.GL_FLOAT, false, 0, mCubeTextureCoordinates);
GLES20.glEnableVertexAttribArray(mTextureCoordinateHandle);
//GLES20.glDisable(GLES20.GL_BLEND);
// get handle to shape's transformation matrix
int mMVPMatrixHandle = GLES20.glGetUniformLocation(mProgram, "uMVPMatrix");
// Apply the projection and view transformation
GLES20.glUniformMatrix4fv(mMVPMatrixHandle, 1, false, mvpMatrix, 0);
//Enable Alpha blending and set blending function
// Draw the triangle
GLES20.glDrawArrays(GLES20.GL_TRIANGLE_FAN, 0, 4);
//Disable Alpha blending
// Disable vertex array
GLES20.glDisableVertexAttribArray(mPositionHandle);
