Did you mail your phone for a replacement? Usually they tell you to remove your SDcard before sending it in for a replacement. You may have to contact your carrier or motorola or whoever you get the replacement from and ask if they have the Sdcard.
The Droid 2 has 8 GB memory, so some of that should be formatted as an SD card partition. Try going to menu>settings>storage and see if it lists an SD card. Perhaps the replacement phone never had the sd card space formatted.
