droid 2 custom boot animation with sound?
sorry to hijack but i deemed it relative for search purposes.
i have the liberty rom and tool box.
i cant find the place where i can change the boot animation, anyone?
I don't know about your particular ROM, but while seeking out boot up sounds I ended up switching my phone over to cyanogenmod. A boot sound mod was written for cyanogen (might work with default rom, not sure) and the boot animation for cyanogen is handled the same as blur.
For your boot animation, try the bootanimation.zip method I posted above.
For the boot sound issue, you might try this on blur, just know if you brick it isn't anyone's fault but your own. ;)
Cyanogenmod Forums -> boot sound
i found it but it says download failed if i try to download it.
and if i try to flash it it says fail not found ??
and thats with all the animations that are available
Try to flash it? This isn't a Rom Manager package. This is a zip file that you just copy to a specific location.
Download one of the bootanimation.zip files to your computer, then put it on your sd card on your phone. Then you go into a terminal emulator, remount the system folder as read/write. Then you copy bootanimation.zip into the /system/media folder.
The links I provided even have info for how to build your own custom animations if you are having problems downloading one.
