S SLICK_N_STICKY Lurker Dec 19, 2010 #1 Does anyone know if a Droid 2 battery will fit a Droid 2 Global?
D Dakota - Tom Well-Known Member Dec 21, 2010 #2 If you check the Verizon web site, you will see that the same battery is compatible with both the D2 and the D2G.
N NiceGuysFinishLast Android Enthusiast Dec 27, 2010 #4 Also, the BP7X extended battery is the same for all of them.
