Help Droid 2 handcent problem (not the double notification problem)....
I sent a mass text out today.... people started responding.... But I am left with 1 notification for an unread text. Well, I have read that text, but it won't clear. I deleted the specific text, it won't clear the 1 in my status bar. When I pull my status bar dropdown menu, it shows the text, so I click on it and handcent force closes. I deleted the entire thread from the person, still didn't clear. Powered down, still didn't clear. DELETED handcent and reinstalled, still didn't clear.
IDK what else to do.... any suggestions?
well, I take this back, it doesn't seem to be a Handcent problem, but rather, just a messaging problem. I have completely removed handcent and the notification is still there.
Try going to Settings>Applications>Manage select the All Apps tab and then the Messaging app and clear cache and data.
Just a random second suggestion if above doesn't work....maybe delete the contact that it went to/came from?
After that Factory Reset is about all that's left...
I m using galaxy 3-i5801 apollo & facing the same problem...did d clear data thing but stilll d prob persist...dont know how to go about now
Tried going to Settings -> applications -> Manage applications -> Text messaging -> clear data? I'm pretty sure this will delete ALL your texts, though.
