Help Droid 2 Help! won't turn on.
I have a droid 2 had for acouple of months now and i dropped it. crack the digitizer. bought a replacement. replaced said digitizer. And accidently ripped the flex cable on accident. bought new flex cable installed. made sure connections were correct. LCD will not turn on. The charge light will turn on with charger plugged in but will not do anything other than that. Any help would be GREATLY appreaciated.
Upon further inspection there is a TINY hole in the flex cable. could that be a problem? any help would be greatly appreactiated!!! thanks abunch
