Droid 2 Navigation
lgp4110
Verizon reset my Droid 2 to the factory settings. Now I cannot use my navigation. How do I reset the navigation?
You likely need to go into your settings and turn on the gps capabilities of your Droid. But to be certain to get it back running as it should you should check in with the other users of your phone for the best advice. Here is a link to that area:
Motorola Droid 2 - Android Forums Good luck and have fun. Welcome to Android Forums.
