This is for the DROID 2 ONLY! Do not flash on your DROID 1 please. I will not help you if you attempt this rom on a DROID 1 and will laugh at you.
For all those having a problem install I have updated the update.zip file. Try it out
Things in the rom:
Removed bloatware(Stupid Verizon!)
Added scripts
Many build.prop mods
This rom is fully Deodexed thanks to bizzshow. Thanks
Themse will be ported. The stock theme comes first!
Still has Motoblur, just took my system folder and edited it a lot. This is the first booted build so please report bugs as you find them to my GTalk matt4542@gmail.com
Thanks to birdman for helping me fix my DROID 2 when I screwed up the system.
The known bug is that the backlight wont turn off when you locked the device, the screen is on but black. Please do not report this bug I will fix it in the next release. This release is buggy and is not for normal use.
Btw I don't have a DROID 1 anymore. DROID 2 now. Will try to keep up D1 development.
I have worked my ass off for this rom so just say thanks!
This has the DROID 1 boot animation for a "retro" feel lol.
READ IMPORTANT!
To install need root and koush's bootstrap app. You will need to make a FULL nandroid backup before doing this because if you screw up your system you can restore. After that go into install zip and toggle the zip authentication check off(or whatever it is) because I wanted this release out so quick I didn't sign the package. DO NOT INSTALL VIA ROM MANAGER!
READ IMPORTANT!
Why the hell have you read all this? Just download it!!
HERE IS YOUR DOWNLOAD!!! Don't you just love me for making you read all that?
DOWNLOAD!!!!!!!!!!!! <--- CLICK ME!
FIRST DROID 2 ROM! Hope you love it!!!!!!
If you post this elsewhere link back to this thread! HOPE YOU ENJOY!
By the way here are your scripts
Scripts:
mountsys - mounts system as read/write
unmountsys - mounts system as read only
blockads - blocks ads from apps
showads - shows ads from apps
free50mb - frees internal memory
free75mb - frees internal memory
free100mb - frees internal memory
movecache - moves your cache to your sdcard
swtchba - switches your boot animation (must be named bootanimation.zip on the root of your sdcard)
switchlwp - swithces your live wallpaper (must be named LiveWallpapers.zip on the root of your sdcard)
reboot - reboots your phone
reboot recovery - reboots into recovery
rmbrowser - Removes stock browser
rmcardock - Removes cardock
rmcorpcal - Removes corporate calendar
rmemail - Removes email
rmgenie - Removes genie widget (news and weather)
rmgooglevoice - Removes google voice
rmim - Removes G1 IM app
rmlauncher2 - Removes Launcher2(ONLY DO IF YOU HAVE OTHER HOME APP)
rmlwps - Removes all live wallpapers
rmmms - Removes mms
rmtalk - Removes google talk
rmyoutube - Removes You Tube
Things in the rom:
Added scripts
READ IMPORTANT!
READ IMPORTANT!
Scripts:
rmmms - Removes mms
. It is stable but there is a decent amount of bugs.
