Help Droid 2 sd card stuff
Kayso, I just got my new Droid 2 in the mail & I'm trying to download ringtones & whatnot, &it says there is no sd card installed when, infact, there is. So I've rebooted it a few times, & removed & replaced the sd card as well, so what more can I do?
If you have your phone plugged into USB and on a mode that reads the USB card to the computer the phone won't be able to write to it. So check that out.
If you don't have anything saved to it yet, then go to the setting, unmount the card, remount it and format it. After a reboot see if it works.
