Help Droid 2 Will Not Turn On, Despite Everything I've Tried Right Now
Droid 2 will not turn on
I woke up this morning, and grabbed my phone. I tried to unlock it, but realize the battery had died overnight.
Usually when this happens, I just plug it in, and it starts charging immediately.
But, nothing happened when I plugged it in. I tried holding down the power button, and that didn't work.
Then I tried to do a soft reset, no response. I tried letting it charge a little bit, didn't work. I tried removing the battery, didn't work. I even tried to hard reset it, but it wouldn't respond.
I also tried turning it on with the battery removed while it was plugged into the ac adapter (I always charge ac adapter, and it has been the whole time, it was never at any point, plugged into my computer). I also tried doing these with the battery removed.
Any suggestions on what to do? The phone is obviously charging, because the white light next to the usb/power plug-thing lights up when it is plugged in.
What should I do? (note again: Factory Reset DOES NOT work).
- Thanks In ADvance
And going into bootloader would be impossible, because the arrow keys on my physical keyboard, do not work. At all.
Any help is appreciated,
