Droid 2
Jennmonc
Can I still use my droid 2 if the touch screen won't work? I'm trying to do a reset on it and I get stuck when I need to push settings because my screen is frozen. Please advise.
Hi Jennmonc!
Welcome to AF! Bummer you're having trouble -- hard to say if you can use the phone or not. Usually you should be able to use the directional keys and spacebar to select stuff. Though if you find that those aren't working it might be time to give a call to whomever you bought the phone from.
Another place to ask might be our Droid 2 forums here:
Motorola Droid 2 - Android Forums
_____
Welcome to the forums :)
Unfortunately it sounds like a hardware failure. As ALP suggested, you could try the Droid 2 forum, or if you can't find any assistance there, try your network provider.
