I've had this problem for a while with my droid 3. When I use my gps it takes a while to "find my position," it often loses the signal while driving and sometimes it says I'm going in a direction I'm not and fixes itself after a little bit of driving which can be quite annoying when I know a turn is coming up soon and I don't really have a hand free to check what road it is.
I'm using CM9 currently but I had this problem with other roms so I don't think that's the issue.
Is anyone else experiencing this? I miss having the awesomeness of my og droid's gps, that thing was spot on. If you have been experiencing this, have you found a fix or are you just biting your tongue and dealing with it.
