Help droid 3 wont turn on
I have a droid 3 that won't turn all the way on. Sometimes I can get the motorola sign to come on & a couple I got to see the main screen. I got an external battery charger so I know the battery is charged 100%. I also tried a new battery & sim card which made no difference. I did notice that around the sim card area in the back gets hot when I try to start it a few times. I also saw a white light where the cord plugs in that I have never seen before. I would very much appreciate any help!! Thanks
Welcome to AF!!
I moved your thread here to better assist you with your issue.
I hope the good folks here will answer your question for ya :)
try wiping cache
with phone off, press and hold m key, press power
select android recovery
at !, triangle, and android andy
press both volume buttons
try wiping cache
If that doesn't help, you can also use the same procedure to try a wipe data/factory reset. Just a warning that this means setting everything up again from scratch, so it's a last resort thing...
I tried the ideas you guys gave me, but they didn't work. I assume the screen should have lit up & selected options from there but nothing happened. Is there anything else I could try or is it a goner?
