Help Droid 4 Flashed to Page Plus (3G) Keeps Losing 3G Data
JahmezzT
So I have a Verizon Droid 4 that is running Android 4.1.2 (Un-Rooted). I have had it fully flashed over to Page Plus (Phone and Data) so the data that I have to currently use is 3G vs. 4G LTE.
Last Tuesday I noticed that my 3G Data had stopped working. No biggie I thought, I just turned my phone off and back on. 3G back…but only for about 14 minutes. After 14 minutes the data disconnected. At this point I am a little concerned. I attempt a few different avenues to restart the data, Airplane Mode On/Off. I’ve done a Data On/Off, Hard Reset, Safe Mode Start, turning off Wi-Fi and starting…same results. The phone turns on and the 3G data lasts about 14 minutes and then it disconnects.
Wi-Fi works, Phone and Text Work (except for MMS).
Here goes a brief list of things I have tried ( I have not attempted a Factory Reset, that is one of my last resorts; I have Wi-Fi most places so I can manage or I just reboot my phone when I need data). I have done the following:
  • Resetting the Phone by Holding down Power Button For 10 Seconds or until phone cuts off
  • Hard Reset by holding down Volume Down Button for 10 Seconds or until phone cuts off
  • Powering Off and turning back on
  • Restarting Phone in Safe Mode
  • Resetting APN to Default Settings
  • Turning ‘Data enabled’ off and back on (Settings -> Wireless & Networks --> More -> More -> Mobile Networks
  • Turning ‘Mobile data’ off and back on (Settings --> Wireless & Networks --> Data usage)
  • Confirmed Network is set to CDMA/LTE
  • Airplane Mode Off/On
Someone mentioned that this may be a hardware issue. Not sure about that, but any info that I might be able to get would be helpful.
Thanks!
I see you done everything but something that is called BUILD.PROP . did you edit the prop if not everything isn't done . now what did you flash from gsm or it was a CDMA already .
Hey BRAINZ2013, thanks for the reply! No I haven't done the BUILD.PROP. I have no idea what that is either so any info on that could be good. My Droid was CDMA already
Yes either one needs the edit cause it was another carrier . did you do the manual programming from the carrier with the mdn and sid .
Whats the trick to flash the droid4 to work with pageplus? anyone have a link, searching google this seems to be the only result. I just got a droid 4 and would like to use it with pageplus
