Could somebody either make the Droid X Boot animation for CM7 or tell me how? I have Tickerguys 9/20 build, so there shouldn't be a customization problem.
Thanks!
i put it in thunder rom.... just open up the rom, got to system/media and take out the bootanimation.zip and there you go droid boot animation!
So we could take that zip and use cwm to flash it to any rom?
no... the bootanimation.zip isnt flashable. just use root explorer to put it in the right place and then reboot
In CM7 it is in /system/media (same as where you would get it from ziggy's ROM). You can also find it, and many other animations online if you look a little bit. They are not hard to find.
system/media it should be the same. use root explorer or es file explorer to copy and past to that folder(make sure ur app has root permissions)Where do we put this in the stock ROM?
There isn't a bootanimation.zip file in there on stock, do I just add it?
Are you using a ROM or stock froyo?
try in /system/media first, and then reboot, if it doesn't work try the /hidden folder.
