droid brothers with youtube---help me out
Jeffruby
driving me NUTS!!! please help...
posted in another thread...my youtube app on droid works....but once im logged in it does NOT update. (need to use browser to see new videos).
can someon please check for me (if you have droid and logged in youtube app)-
go to your phone options
accounts and sync
next to your youtube account does it say "sync is off"- i am unable to turn it on. top two checks are checked (allowing sync for all) and my facebook and gmail are green (syncing)
help!!!
thx
I have the same problem.
I tried to call tech support later in the evening, and you could very much tell that the call center was NOT USA based. Also the calls kept dropping on their end after about 5-10 mins.
Try calling tech support, the number is on the moto site! If there's a fix, I'd love to know what it is.
I did post in the "other" youtube thread here, that there is a fix for the login; at least it worked for me!
aha....so im not crazy...
i think problem is that the sync with droid is not avail!
so youtube app that comes with droid needs update!
it is broken as it does not update (sync) with whats going on afteer you log in
best use browser til fixed!!
I don't have time to call them this afternoon, but please call Motorola and log your complaints so that they can fix them!
