Yep, I bought mine with the phone at the store the week the phone came out.Correct me if I'm wrong but haven't these have been available in-store since launch?
It's been available in-store since launch for $29.99. This was the first accessory that I purchased for the Incredible, as I wanted a decent holster. Up until the belt clip broke this past weekend, it sufficed.not sure this may be a off brand, but it would do the job it seems. As for Verizon i have not heard of them having any car mounts for the incredible. I also searched the Verizon site and could not find anything, if its not on the website it more than likely wont be in the store.
This is awesome. I was bummed about getting rid of my droid because it has this badass nav window mount, but now I see this is available and it makes it all better.
Not yet... I did buy a "Bell" (same people who make helmets) one from K-Mart for ~$7 that isn't terrible, but I want something better. What I know for sure is to get one with two clips and ideally, three or four. This one has just one clip and therefore "rocks" side to side unless I connect the charger and that tension helps hold it a little. This is in my Accord, in which the vents are fairly flat up/down. In our Odyssey, the vents are sloped quite a bit and the phone therefore faces "up" just a little too much.Anyone know of one that clips onto the ac vents that works well?
I'm really still favoring a vent-mounted type solely because of how hot the phone gets when using GPS or WiFi tethering. Of course, this won't help in the winter... Actually, I'd be afraid to run both at the same time as I'd surely cook the phone !!
