i recently bought a Droid Charge was was described as non-rooted phone from eBay. got the phone activated it everything works fine except the Google Play app is missing! i tried the OTA update only to fine the phone freezes and then a yellow triangle appears with the little android guy putting his hand up. i pull the battery and turn it on.
- i pull the battery and this is the screen i get..
CwM Voodoo Lagfix Recovery v3.0.2.8x
-reboot system now
-apply update from sdcar
-wipe/factory reset
-wipe cache partition
-install zip from sdcard
-backup and restore
-mounts and storage
-advanced
-voodoo
-power off
E:missing bitmap icon_clockwork
(code -1)
Obviously this phone had been rooted. i dont have the original sdcard that came with the device.
any thoughts or am i at a dead end road and should just return the device. thankyou!!!
-reboot system now
-wipe/factory reset
-backup and restore
-mounts and storage
-advanced
-voodoo
-power off
(code -1)
