TivoTron
I am loving the Droid as my go-to car navigation system. It's really pretty sweet.
However, there are three issues that I'd like to bring up in hopes that others have had similar issues and have found solutions.
1) Calls should default to speakerphone. It's a little weird that when you make or receive a call while in the car dock that it doesn't automatically go to the speakerphone mode. Instead, you have to try to press the little "speaker" button which, while driving, often results in pressing another button and further distracting you from driving.
2) When calls end, it should return to navigation map. During a call, the screen times out. When the call ends, it stays black, causing you again to have to press the ON button, enter the touch password and get back to navigation. Even better, during the call, there should be an easy way to switch to navigation instead of having the call screen showing (BTW --- why doesn't that call screen switch to landscape mode when in the GPS dock?)
3) Navigation volume should be lower during calls (or at least give you the option). I've had to pause my calls while waiting for the navigation to tell me to stay on the highway.
Thanks!
Thanks!
