In two phone calls on the droid i adjusted slightly, and i've hung up on the caller. Don't know if there's any solution to this because I know you take the phone away from your head to hang up... maybe my face is too small or something... registering as a "screen on". Thoughts?
Could be an issue with your sensor. Does the screen turn off with the phone next to your face like it should? If not I would probably head on over to the Verizon store to get it checked out.
Yes, I noticed it turning on/turning off (I tested it out...)... I'm not sure what the typical sensor space is between the face and the display coming on/off.
