Zenze
Motorola's 4.3-inch Droid Shadow found in a unicorn gym? -- Engadget
So the droid shadow as been seen a couple times now and it has me debating as to whether or not I should go ahead and get a Incredible or wait for the Shadow.
Honestly my biggest concern about the two phones is that I would prefer to have stock android over the Sense UI on the Incredible. I have heard through a couple posts/comments that the Motoblur on the Shadow will be able to be turned off and you can use stock android, which would be great because I heard Motoblur is terrible. Is this possible on other phones with Motoblur or not really?
Also, what does it take to put a stock android ROM on the Incredible or Shadow? Maybe that would be my best bet.
