Droid Incredible with multiple issues
chewyheel
So I turned my phone on this morning and to my dismay several things aren't working right. When I turned it off the night before everything was fine.
The two biggest issues are text messages and internet. It lets me know when I get a text message, but when I want to actually read and respond the screen will not load. Also the internet isn't working. The browser comes up to my homepage but it won't let me type in a url even though I'm connected to wifi.
My apps are also running slow and the time & location settings aren't functioning properly.
Model #: ADR6300
Kernel Version: 2.6.35.13-g22d3486
Build #: 4.08.605.19 CL539174 release-keys
Baseband Version: 2.15.10.12.20
The phone was previously on Verizon, but now I use Page Plus as my carrier and haven't modified it in any way. I am in the US.
Any help would be awesome.
Hi Chewy, have your tried hard resetting your phone ?
Sometimes your phone just simply needs a restart, If you hold down the power button or just tap it most phones have a shut down and restart option that might help with that.
Also, might I suggest that you try clearing the data in your SMS and Internet through the application manager.
I turned it off an on this morning and that didn't work. I just did it again though and it seems to have worked this time since it seems to be working normally again. Thanks for the tip.
No worries, just remember if you run across the problem again to hard reset it or just simply turn it off and on again. :)
