Old Member
Android Expert
I thought it would be nice to have a place to list any bugs or problems with the Maxx as they arise.
Use this thread to list any bugs or problems. Sometimes they aren't bugs at all, they are features you're not sure how to use and they come across as bugs, other times they are in fact bugs that should be reported.
I have a spot on my display near the bottom right of the screen that I can see two small dark spots under the glass. I can only see them when the screen is off and only when I tilt it to see the glass in the reflection. They look like a snake bite. I used a dead pixel app and can't see any dead pixels. Just wondering what it is and what caused it. I also may take it into Verizon to have them look at it prior to my 14 days to make sure that it's documented that it is there from the beginning.
All joking aside, it makes me think that Verizon has raised the control freak bar to another level if they don't let you delete phone numbers. I'm sure there are bookmarks that can't be deleted either.
