Root Droid maxx root gliches
Just got done rooting my Droid Maxx, this will be about the 8th phone that I've rooted so I'm not a complete bozo when it comes to rooting. I appreciate those that have come up with the root and have donated when ask for. This last root has done some weird things to the phone
1. Bluetooth commands wont work, answer and call cancel work, but no voice commands. When asked to choose what program I want to use, which it shouldn't, I press google voice and it says program illegally installed.
2. I've change the entitlement to take advantage of my grandfather rights, but it seams like I have to on/off airplane mode to reconnect to 4g to get internet pages to come up , this happens anywhere frome two to 10 minutes on the internet.
3. I've also installed Titanium back up. want to remove allot of the blot, [I never get rid of proprietary programs] after removing programs like NFL football and the like, those programs come back and are re listed in the app pages.
Any thoughts to whats going on. ?
Since the device is rooted and issues tend to be device specific, I've moved this to the Droid Maxx root forum for better support. :)
I'm not sure I've seen anything like this mentioned before. There are a few methods that can be used to root the Maxx. It would be helpful to know which method you used? Also, did the phone get the recent OTA update?
You can disable preloaded apps without rooting. Settings->apps, go to all, tap the app, look for the "disable" button (though I also tap "uninstall updates" first myself.) You didn't have to root for that.
It also turns out that you didn't have to root for the tethering - FoxFi now works on an unrooted Maxx.
