thetrickster213
Can, when changed to GSM etc., the DROID mini work on the T-Mobile network, and in some areas with Band 4 coverage, have 4G LTE? I just need to make sure I can make calls and use texting and Internet with it on a tmobile sim
Definitely change the default networking to GSM/UMTS/LTE (or whichever the order is) away from the default Global. My first thought is don't worry about the APN changes unless you are having problems with MMS messages and internet/app connectivity through T-Mobile's network. It *should* set up the proper APN at this point.So all I have to do is change the APN and delete all others. Also, I have to change the networking mode to GSM ETC
