D
droid mini
Guest
My droid mini Motorola x8 won't connect to try router to use WiFi I reset the router I'm stuck
Read this and see if the suggestions there help:
http://forums.androidcentral.com/am...ooting-wi-fi-connection-problems.html][GUIDE]
If you still are having problems after that, post back here and we can suggest more troubleshooting and configuration options.
did you try to turn your phone off to unlock the ip and refresh once the router opens the ports?
