Ditto. Don't bother with the "Unlimited Data" plan; it's poorly worded and doesn't have that many benefits over the $30 "Web/Email Plan" for most people.Keep your voice plan. $30 per month adds data/email to ANY voice plan.
It sounds like you have an employee discount - 20% off your monthly bill.Yup - it works. Don't let them tell you that you need an unlimited plan - if you only want it for the email and web capabilities, then just add it on.
And when I went through the web, it was discounted to $23.99
You can utilize the Basic and Select Plans with Smartphones so as long as you add a Data Plan (Connect and Premium Plans cannot apply its data usage toward the Smartphones). You can also go for a more expensive Smartphone Plan which is basically a combination of the Basic (or Select) Plan(s) and Unlimited Data Plan.If im correct you need a different plan to even get a smart phone. With the basic plans i dont think the will let you use them.
He got it because he has access to EPP so he saves 20% off his monthly bill. If you don't work at a place that has an EPP with Verizon, you can't get the discount.Where online did you get the discount?
