shadrap
Found this on another forum and it is for the Bionic, but I thought it might also help the Razr. I have done everything stated and will give it a run today and report results. I will use the phone as close to normal "for me" as possible.
If you are having short battery life:
Consider doing a factory reset. Do not sync apps, wifi connections, etc. with Google services as that may cause a problem. Install all apps and wifi connections from scratch. A bit of a pain, but not too bad.- install a home/launcher replacement. I use Go Launcher EX, which is free, and I love it. No reason not to try out an alternative launcher as you can always go back to how you had it.
- Don't use an automatic task killer--not even the one that comes with the phone. Reboot your phone and look at what's running. If anything that you've installed is running and there's no reason for it, then uninstall it and find an alternative that behaves. Ignore any stock apps that run on boot as I've found them to be more or less benign.
- Weather widgets, live wallpapers, news/social feeds, any app or service that you use that runs--do without it if you can. If you can
