Can you get a % indicator on the top of your phone? My friend has it for the droid razr? and I was just wanting to know if I can get it? Like I mean the little battery symbol then it would say "56%"
Do you mean get the % on the right side of the phone(next to the clock) or on the left(with the notifications). If its the latter there are apps for that. If its the former i believe you must be rooted.
Go to the Google Play Store and search for Battery Indicator. Then after installing it, open the app and click on the settings symbol then check the 1% hack. Then you're good to go. I use GSam Battery Monitor (formerly "Badass Battery Monitor").
Gsam battery monitor is the best app you can get. It does way more than just show you the percent. It shows you what apps are using the most amount of battery, what's keeping your phone awake, etc
i use Battery Widget? Reborn! Pro
i like it very much does the % on my razr and dont notice any battery drain at all
i have the setting to show on my status bar and the numbers are very clean looking
