Droid RAZR painfully slow and unresponsive
cEElint
My RAZR has been extremely slow the past year, unusable at times. I am constantly running CleanMaster to free up RAM usage. Is there a fix for this? Would rooting device solve my problems? I've looked around online how to root this phone but didnt really see anything specific, maybe I overlooked it or something. Can someone point in the right direction? Its the regular Droid RAZR xt912 running OTA 4.1.2
Welcome to Android Forums.
Did you Wipe Cache Partition? Almost all performance problems are due to a fragmented cache partition. (I do this on my Droid Turbo every Saturday.)
If you want to investigate root0ing ... visit the All Things Root sub0forum of this forum. That's where you'll find the most information.
... Thom
yea, I've cleared cache... only speeds it up for a short period then its back to being slow again. Sometimes when receiving a call I swipe to answer and it just freezes and I miss the call. Very, very irritating. Every couple hours my RAM reaches 85-90% usage and only gets as low as 45% after clearing everything.
The next step would be to run in Safe Mode (disabling all apps you added without uninstalling them). If the problem stops it is caused by an app that you added.
... Thom
Booted in safe mode and it disabled all third party apps... was very quick and snappy like day one. I've already went and cleaned out nearly all unused, undesired apps and its still a turd. When I run battery Dr it shows a lot of Android guy system files draining the battery
I do occasionally... this has been happening since an update was pushed to my phone. I was checking in my battery Dr app and it shows the android system killing my battery the most .. next is Facebook, then dolphin browser
I've been having the same problem for a while. I have cleared cache. I even have an app caled App Cache Cleaner. After some googling I found this page from Morotola:"
http://www.verizonwireless.com/support/knowledge-base-66428/
It explains how to wipe and reformat the cache partition. The interesting this is it says that clearing the app or browser cache is not the same wiping and reformatting the cache. I just did this and we'll see how it works.
Charlie
Battery Dr says Android system is draining my battery the fastest. So, I'd assume its what is slowing my phone down the most. Still looking for a fix.
I am having the same problem. It lags a lot, although sometimes it works just fine. I loaded Gsam battery monitor and sometimes it lags in notifying me of the battery level and will suddenly show a huge drop. I think there are some kernel wakelocks that prevent the phone from sleeping and use excessive battery, but I don't know which ones are normal, so I don't want to try to disable anything. I did a cache partition wipe but no difference. I was wondering about formatting the cache partition.
Sometimes when my phone is really struggling, and won't respond to touching the screen, or the keys at the bottom, the back light for the keys will blink slowly. I'm not sure if blink is the right way to describe it, but basically the back light turns off and back on for a few moments at a time. I have checked to see which apps are running, if possible, and the ram is around 90% in use, and will fluctuate a little, showing different apps running and then disappearing from the list. I was wondering if anyone else has seen this happen or knows what is going on.
How do you "Wipe Cache Partition"? I know how to clear cache for an individual app (menu; system settings; apps; <choose app>; clear cache), but how do you do it for all apps at once?
Verizon, Android 4.1.2
From Verizon website ...
Performing a wipe cache partition removes any temporary files that may be causing an issue with the device. All personal files and settings are not affected by this option.
  1. Power the device off.
  2. Press and hold the Volume Up and Down button then press the Power button.
  3. When presented with the Boot Mode Selection Menu, release all buttons.
  4. Press Volume Down button to select 'Recovery' then press the Volume Up button.
  5. From the Droid triage screen:
    1. Press and hold the Volume down button.
    2. Press and release the Volume up button.
    3. Release the Volume down button.
  6. Select wipe cache partition then press the Power button.
    Use Volume keys to navigate options.
  7. Select reboot system now then press the Power button.
... Thom
Whoa! That was fantastic. I never would have figured that out on my own. Usually, when people tell me how to do something, there's always some step that's not clear. But this was very well presented. The only pause I had was with the "Droid triage screen". I expected three items but just saw Mr. Droid on his back with his compartment door open. But that seemed to be the proper screen.
My cache is now clean & ready to go.
