Root Droid razr running rooted 4.0.4
Marquin
Hi guys I'm having a bit of trouble n i have been trying to figure this problem out or a few months now but i have not got the answer i know I'm really good with instruction i have been a rookie n learn n read about how to root my phone n every thing so i have rooted my device i also have install safestrap recovery now its time to install the room i have find a rom i like a few the problem i am having is getting them to work ok i put the rom on the phone i boot into recovery i factory reset n wipe everything i than enable safe system n wipe everything again n i keep getting error mission aborted or sum when it tries to install rom can some one please guide me n help me so i can be a happy rooted user :)) kindy rite me here
I think its when u do a factory reset is when u lose it just wipe what u have to then boot into safestrap add the rom from ur zip on ur sd card then just reboot after it tells u the rom was installed and it should b fine plus just for good measure format ur sd card then redownload ur roms u want and then try to install the rom
