Hi all,
please help if somebody experienced following issue:
I'm little suspicious regarding the service since they usually do all to avoid replacing and repairing the device. Is this a hardware failure or some software issue that can be fixed? I didn't managed to backup all my data since I didn't expected from Motorola to have such an issue...
- turned on my razr - battery 90%, worked fine while I was reading some emails for a 10 mins
- while scrolling to second desktop screen it froze up?! I couldn't do anything - screen was just displaying the same, all buttons were dead
- I preformed the soft reset - VOLUME UP + VOLUME DOWN + POWER all at the same time and it turned off
- but it couldn't be TURNED ON at all. Tried putting it again on the wall charger, via USB on laptop, pressing all possible buttons combinations at the same time...NOTHING
- LEFT IN THE SERVICE CENTRE..
