Droid Razr won't use custom ringtones created using Ringdroid
rhpbfh
I have downloaded Ringdroid and created a few custom ringtones on my Droid Razr purchased a couple days ago. When I go to the Sounds menu and choose one of the custom ringtones as my ringtone, the phone shows "unknown ringtone" after I have saved the selection and will not use the ringtone.
Hello and welcome aboard...
You might wanna clear data from the app and start the process over again. Or install and try this application... zedge.
Best of luck. :)
Glad to have you
images
I just ran across this same problem. I used file manager to move the new ringtone mp3 into the ringtone folder. It fixed the problem for me.
