There are three colors that have lit up so far on mine, red, green and orange. the lights are much nicer looking than the dinc.
from another forum, I can confirm that ChompSMS does the color changeWould it be possible for you to use another app that allows you to change the colors such as ChompSMS or Handcent? Having a blue LED for texts is pretty handy on my Droid.
I thought tri-color meant the rgb format. Can anyone confirm a blue LED? try one of the sms apps mentioned above.
You can see at least two colors in the following video: Green and White
YouTube - Motorola DROID X review - part 3
