I've gone through previous threads and can't find anything that will work. Last week a friend dropped my DroidX into a puddle briefly.
I took the
battery out and made sure everything was dry. It seemed like the case collected most of the water and it was only a second. The phone acted wacky at first.....unable to answer or unable to hear caller. Like I said....turned off and took out battery. Everything seemed to operate normally after I did that. About an hour later it went into safe mode and the soft menu key will not work. I have tried most of the methods suggested in the forum. Any ideas? Other than that, the phone works fine. Thanks.
I took the battery out and made sure everything was dry. It seemed like the case collected most of the water and it was only a second. The phone acted wacky at first.....unable to answer or unable to hear caller. Like I said....turned off and took out battery. Everything seemed to operate normally after I did that. About an hour later it went into safe mode and the soft menu key will not work. I have tried most of the methods suggested in the forum. Any ideas? Other than that, the phone works fine. Thanks.
