F fbm111 Well-Known Member Sep 25, 2011 #1 App keeps getting error message sd card not mounted or full. I have 32 gb card with 17 gb free. HTC thunderbolt. Any ideas? Never used app before. Thanks
J jerofld Fixing stuff is not easy Sep 25, 2011 #2 Is your charge cable connected and you're in Disk Mode?
F fbm111 Well-Known Member Sep 25, 2011 #3 I was charging but not in disk mode. Unplugged and got same error. Unmounted and remounted and got same error. Confused.....
J jerofld Fixing stuff is not easy Sep 25, 2011 #4 Try a reboot / battery pull? If that doesn't work, and you can access your SD card normally, it's a busted app. (I've never used it, either)
F fbm111 Well-Known Member Sep 25, 2011 #5 I will try reboot, should have thought of that. I have not rebooted since I installed app maybe that will work.
