SOCOM-HERO
Whenever I come home, my DroidX tries to connect to my router and seems to be killing it every time it tries to connect. I would summarize the problem as that. By "killing" I mean that the router goes into a reboot and therefore kills its signal for about 30 seconds. The DX will continue to try and connect to the router and fail over and over again, but eventually connects ONLY on a screen timeout. If I go into the wifi settings in the phone, I can see that it finds the router, IP and then attempts to connect...and then the router reboots. It is the PHONE's fault somehow and I need to correct it. It only happens with my phone, as other phones in the house have no issue connecting to my router. Tested on two routers so far, and in both cases, my DX is somehow causing them to reboot when it attempts to connect. This is VERY annoying. Running Liberty v2.0 on 2.3.3 (.605version).
Any response will be met with thanks!
